timing marks on the crankshaft for a 2.3L ?
1995 FORD RANGER
170 MILES
JOHN SLONES
I recently had to change the timing belt on my truck because it had slipped. I found the markings on the others, but I am unsure of where the marks are for the crank.
Sep 6, 2011 at 1:23 PM
WRENCHTECH
  • CAR REPAIR CONTRIBUTOR
  • 20,761 POSTS
The keyway has to go straight up here is a guide to help you see where the marks are.
https://www.2carpros.com/diagrams/ford/ranger/1995
Oct 27, 2018 at 4:29 PM
FROG20015
I cannot get it to stay timed.
Nov 11, 2020 at 6:26 PM (Merged)
  • 54,350 POSTS
Here is a diagram to help, check the tension of the belt also check the bottom drive gear it could be moving around on the key way I have seen this before
Let me know what you find
2CP-ARCHIVES
  • 4,540 POSTS
1995 Ford Ranger mileage: 140,000. What would cause timing belt to jump a notch?
2CP-ARCHIVES
  • 4,540 POSTS
As the timing belt wears it becomes stretched out and that can cause it to jump.
CJ MEDEVAC
  • 11,004 POSTS
Thats why they really recommend that they be changed at a SCHEDULED INTERVAL, I've mostly seen 60,000 miles being that interval, usually outlined in your owners manual or in the "Scheduled Maintenance" section of a Repair Manual.
Much grief could be avoided, if people would just do this maintenance, instead of waiting till it's too late.
The Medic
DONALDLEDFORD
Engine Mechanical problem
1994 Ford Ranger 4 cyl Two Wheel Drive Manual
what are the timing marks and where are they suppose to be
Nov 11, 2020 at 6:27 PM (Merged)
BLACKOP555
  • 10,386 POSTS
timing marks are used to align the valve timing for the camshaft and crankshaft. they are usually indentations/markings on camshaft and crankshaft pulleys.
https://www.2carpros.com/diagrams/ford/ranger/1994
usually right above the keyway.
XTRAVAGANT1
  • 5 POSTS
hello!!! i was wondering if the engine timing was off, will the ignition coils have spark???
BMRFIXIT
  • 19,053 POSTS
when you say off do you mean off timing or off broken off you should check if the cam turning ,and if so check the crank sensor ,fuses and relays
