No Spark?
OLDFART5256
  • 2005 FORD RANGER
  • 2.3L
  • 4 CYL
  • 175 MILES
No fire to plugs replaced coil still no fire and I have 12 volts to the coil
Thursday, February 13th, 2014 AT 8:45 AM
HMAC300
  • 48,601 POSTS
Check fuses underhood first as one may have blown, then scan for codes. also circuit breaker 1a and 32 in the smart junction box. then check crank and cam sensors against new ones resistance wise
This guide can help us
Thursday, February 13th, 2014 AT 9:35 AM
MIKE LUCKEY
  • 38 POSTS
The old rangers had what was known as an inertia switch that would shut off power to the fuel pump, and also shut down spark in the event of an accident. Sometimes these switches would fail. If you can't hear the fuel pump cycle, I would look to see if the new rangers have something similar. Also, If both of these things fail, you could have a bad PCM relay. You should hear/feel it click when you turn the switch to the on position. Hope this helps.
Saturday, February 15th, 2014 AT 7:23 PM
2CP-ARCHIVES
  • 4,542 POSTS
  • 1999 FORD RANGER
  • 75,000 MILES
Got stranded the other day. There's plenty of battery so the engine cranks but it just won't catch. Acts like there is no spark or fuel getting to the cylenders. It's happened twice now - both times during wet weather but there are no obvious signs of moisture anywhere in the engine compartment. The first time it started an hour later and then ran fine. This time it still won't start. Any thoughts on what it could be?
Wednesday, July 29th, 2020 AT 11:38 AM (Merged)
JDL
  • 16,098 POSTS
Have a helper crank it while you visually check for spark at the spark plugs. If you have spark everywhere, use a gage and check fuel pressure. You got to start testing, somewhere.
PACHYAUTO63
  • 40 POSTS
  • 1999 FORD RANGER
  • 3.0L
  • 6 CYL
  • 175,000 MILES
Put new coil, new plugs and wires, new heads, and injectors, but cylinder three has no fire. What could be my problem now?
Wednesday, July 29th, 2020 AT 11:39 AM (Merged)
  • 52,797 POSTS
Good afternoon.
I would start by doing a compression test to see if there is an internal issue with the engine.
Also, if you have a noid light, check the injector harness for the cylinder and see if there is a flashing light on the noid to be sure the ECM is grounding the injector to fire.
https://www.2carpros.com/articles/how-to-test-a-fuel-injector
PACHYAUTO63
  • 40 POSTS
We already did compression test and noid light.
Everything was good.
  • 52,797 POSTS
Okay, you need to go back and re check.
Go to basics. Is there spark at the plug?
Is the injector firing or being commanded to fire?
If you have a vacuum gauge, check the vacuum at idle and see if it is steady at 20 inches.
DLG13070
  • 1996 FORD RANGER
  • 6 CYL
  • MANUAL
  • 186,000 MILES
My Ranger shutoff a week ago on a thursday night all the guages showed normal operating conditions. I was driving and lost enginge power, tried shift gears and no go. Coasted to a stop and turn off all accessories, a/c and phone charger, engine cranked back up then. Three days later it cut off again same feel and situation this time it did not turn back on. Thought it was the fuel system so replaced pump, guage was out anyways, and fuel filter. I am getting plenty of fuel to my injectors and can smell it coming out of the tail pipe when trying to turn the engine over. So next step I decided to check spark, pulled the Number one plug and held it and wire next to exhaust manifold to see if I could get a spark to jump and did not get a spark. Plug looked good still and the wires are less then two years old. I think it might be the DIS ignition coil pack. Is there anyway to test it, and if it is not it what other parts of the igniton system could be affecting this?
Wednesday, July 29th, 2020 AT 11:40 AM (Merged)
DOCFIXIT
  • 18,828 POSTS
Hi
at coli connection find Red/Light Green wire key on power? If yes place test light on any yellow striped wire crank does it flash?
Let me know
Thanks for donate
DLG13070
I tried the using the test light on the wires mentioned and did not get the flashing light. I test my test light on other connections and it was working.
DOCFIXIT
  • 18,828 POSTS
Was there voltage on Red/Light Green?
DLG13070
Didn't light up but I'll check there again. I checked all of the relays as well. Charging battery back up ince it died last night while trying to get it to crank.
2 LINSEY
  • 287 POSTS
Hi dlg, how are you doing with your testing? Thank you for using 2CarPros. Com. We appreciate your donation and look forward to helping you in the future.
JOSECHULO20
  • 1995 FORD RANGER
  • 4 CYL
  • MANUAL
  • 187,000 MILES
Ive changed both the crank sensor and the cam sensor also the coils wires and the spark plugs but still no spark I checked wiring to the coils there is no power there either I wanted to replace the ignition control module but I cannot find it someone told me it maybe inside the computer is this true
Wednesday, July 29th, 2020 AT 11:41 AM (Merged)
IANHIESTAND
  • 14 POSTS
Your truck has a DIS (Distributorless Ignition System) so therefore it doesnt have an Ignition Control Module. Just to be sure before you buy anything, check ALL fuses, Underhood and Driver side dash. If all good or replaced and no diference. Call up a local salvage yard and get a PCM or Computer and you will be fixed.
AGURGANU
  • 1994 FORD RANGER
  • 4 CYL
  • MANUAL
  • 124,000 MILES
I recently replaced the starter in my 94 ranger, 2.3 ltr 5 sp. The starter was bad and had to be replaced, and when we tried to start it, the truck just cranked and cranked without starting. I was hoping that my son didn't fry the computer by hooking up the positive cable last. Also I have an autoxray 2500 that would not read the computer at all, and the check engine light does not work when the key is turned on initially. Please help
Tony
Wednesday, July 29th, 2020 AT 11:42 AM (Merged)
DOCFIXIT
  • 18,828 POSTS
Check fuse #4 in under hood box
AGURGANU
Two ground wires coming from the battery for the fuel pump and the ecc was barely connected. After I connected them the truck finally came alive. I'm sure it was from my son and I tugging on the starter cables
thanks anyway for your help
DJMOY702
  • 1994 FORD RANGER
Electrical problem
1994 Ford Ranger 6 cyl Two Wheel Drive Automatic
i had made a mistake of connecting the battery wrong the positive on the negative and negative on the positive and sparks came out and then I try to start the car but it only crank now it doesnt want to start I have check all the sensor and relays and I change the computer and spark plugs and cables, and the coil but there is no spark for the motor to start can u help me get a spark?
