Mechanics
BROKEN TIMING BELT
1994 Ford Ranger
Engine Mechanical problem
1994 Ford Ranger 4 cyl Two Wheel Drive Manual 22100 miles
my timing belt broke how do I find which stroke is TDC #1 cylinder with the cam disengaged the cam is in TDC position so my # ! Cylinder has air pressure through spakplug hole at both top positions because exhaust valve does not open on exhaust stroke thanks Bruce
Bruce C
May 28, 2009.
Hello, you might check out this link, see if it helps?
http://www.2carpros.com/articles/mitchell1eautorepair-car-repair-manuals
JDL
May 28, 2009.
AD
