Mechanics
STARTER SOLENOID
1991 Ford Ranger
Electrical problem
1991 Ford Ranger 6 cyl Two Wheel Drive Automatic
The engine will not turn over. I get one click from the starter solenoid. Can it be tested? Does it have to be removed to be tested? The battery is almost new.
AD
Jollyjoal
July 17, 2009.
Remove the red and light blue wire on the starter relay-have helper hold key to start positon -do you have power if not -check the back-up/neutral safety switch pink wire no power here -the problem is coming from the ignition switch-power at the back-up/neutral switch-this is switch is defective.
Rasmataz
Jul 18, 2009.
AD
