Ford Question
Asked on November 14, 2008
1990 Ford Ranger Problem
Upgrade Question
Get Answer Now
Ranger Will Not Start
Engine Mechanical problem
1990 Ford Ranger 6 cyl Two Wheel Drive Manual
Started and ran good one day next morning tried to start, will not start. turns over just will not start. took air filter hose off and sprayed starter fluid in would run until fluid burns up then nothing.
Avatar Asked by richbnsf
+ follow question
Replies
Replied on November 14, 2008
From what you're saying, you have a problem in your fuel system. Your engine is not getting gas.
Is your fuel pump coming on when you turn your key to ON?
If not, check your fuse, relay, and inertia safety switch. If they are all good, check for voltage at the pump. If there's voltage at the pump but pump doesn't come on, it's probably bad.
If your pump is working fine, I would take a look at your injectors: do they get a pulse signal from your ecm, do they have voltage?
Start with a fuel pressure test; it will tell you if you have low fuel pressure if any at all.
A low fuel pressure could be the result of a leak somewhere in the fuel lines, a clogged fuel filter, a leaky fuel pressure regulator, leaky injector, or low voltage at the pump.
Come back with what you find out.
Avatar Response from renaudTN
552 answers provided
Sign in to leave a reply!
Donate
Your Donation Helps
Related Questions
Related Articles
Didn't Find What You're Looking For?
Check Our Main Topics:
