1997 Ford Probe Repair Question
Topics covered: Crankshaft, Timing belt.
Asked on April 22, 2007
97 Ford Probe
Thanks for any HELP. I am having trouble getting the Crankshaft pully bolt loose. 125lbs of air didn't break it loose. Is it reversed threads by chance? I tried a heat gun on the bolt, even tried to hit it a couple of time with a hammer / chisel ( conter clockwise) but no luck. Any ideas?
Answer
Replied on April 23, 2007
If an air impact didn't remove it one way...nothin to loose going the other! don't use too much heat, timing belt is rubber!
