I have a problem starting the car there are no fault codes showing in the diaonostics. The starter motor will not not start nthe engine but will if the you bump start it, then runs perfectley until you turn the ignition of then will not start. So far have replaced the crankshaft position sensor and a new starter motor fitted. Also have checked the ignition circuit all appears to be ok.
Aug 23, 2010 at 5:52 AM
