1993 Ford Probe Repair Question
Topics covered: Engine, Check engine light, Backfire.
Asked on August 20, 2010
Timing/distributer
Engine Performance problem
1993 Ford Probe 4 cyl Front Wheel Drive Manual 120000 miles
Ive got a 93 probe se. The check engine light stays on. when it starts it will run fine. But after it warms up, if the check engine light shuts off, when you give it gas, it will run erratic almost like a timing issue, then die. it wont start back up until the check enging light turns back on and it will run fine. But if it is off, it will die and miss out heavily, backfire and jump rpms from 500 to 2500 and hit and miss on cylinders. blocked off the egr valve, and still had the problem. im lost at this point.
Answer
Replied on August 20, 2010
You need to get the stored code numbers first.
