1990 Ford Probe Repair Question
Asked on October 28, 2010
1990 Ford Probe
Engine Performance problem
1990 Ford Probe 4 cyl Two Wheel Drive Manual 69000 miles
My 1990 GT Probe turbo
when I start tHE car it makes a electric sound like for a second a few times as i run the car when I brake it make a thumping sound on the left side like if the caliper would be loose but everything it's fine when the noise stops is fine and it brakes fine . The other problem is I can't run the car above 3.5 rpm cause it starts to gag(don't know how to explain it) is mostly when the psi activates and it doesn't activate above not even close to 6 psi What could it be??? if I ride the car with out quick accelaration runs fine it doesn't smoke the oil is fine it doesn't heat up at all what could it all be???? please help anybody or as many possible appreciate it thanx MR
