1989 Ford Probe Repair Question
Asked on March 31, 2006
1989 ford probe pickle
If you could fix this, your a god. i have had to change the distrib,and coil 3 times and the fuel mod. every thing ran fine till now, the oil guage will drop to 0 and goes back to norm. then back to 0 and the temp will flux a bit and the rpm will goto 0 then flux as well,the car drives fine for a bit then dies and wont start like as if no spark. i let it sit or keep starting it and it will start but die or start, seem to run fine then it does it all over again.the last 3 times this happend i chaged the distrib.and seem to fix.is it my distrib. again or is it something eles like a oil pump or sending unit? (also it is all digital dash) HELP?!
thanks,
jay
thanks,
jay
Answer
Replied on March 31, 2006
I need to know in plain terms what the Probe is or is not doing at this moment. Also the mileage and engine type would be helpful.
