Mechanics
MODELS CLUTCH PROBLEM
2002 Ford Other
Noises problem
2002 Other Ford Models Two Wheel Drive Manual 3200 miles
Hi, I have recently had a problem with my clutch. When slowing down to pull over or park, I brake and put my clutch right down to change to first gear. As I do this, if I move the steering wheel, the clutch seems to move under my foot, and it is noticeable because the rubber part on the end of it squeaks under my foot. It is not a problem, but it is annoying. Do you have any idea what it is and if it needs to be fixed? Thanks,
liv x
Livster182
January 18, 2009.
Hi where your clutch pedal and brake pedal hook together there are plastic bushings there you need to replace these bushings. This will fix this prob
Billymac
Mar 30, 2009.
