1996 Ford Other Repair Question
Topics covered: Battery, Alternator, Radio.
Asked on August 22, 2010
Models battery drain
Electrical problem
1996 Other Ford Models V8 Two Wheel Drive Automatic 85000 miles
Ford e 150 van battery and alternator has been checked (good). Hooked volt meter between negative battery post and cable pulled one fuse at a time and voltage did not change (voltage is 11.9) This is a conversion van by Mark III has tv,vcr powered sofa bed. Radio has not come on in nearly a year but after jump starting the lights came on the radio and the battery still drains down. any suggestions. Thanks Phil
Answer
Replied on August 22, 2010
Try disconnecting the alternator and see what happens
