camshaft position sensor location?
2006 FORD MUSTANG
ANONYMOUS
Where is bank 1 of the camshaft position sensor? As your looking at the engine is it on the left of right?
Jan 7, 2013 at 7:39 PM
WRENCHTECH
  • CAR REPAIR CONTRIBUTOR
  • 20,761 POSTS
Here is a guide to walk you through the steps of changing the camshaft sensor and diagrams below to show you the location and instructions on both six and eight cylinder engines.
https://www.2carpros.com/articles/camshaft-angle-sensor-replacement
Jan 7, 2013 at 7:50 PM
GPW
location of the camshaft positioning sensor on the 2004 mustang 3.9 v-6.
Jan 18, 2019 at 5:47 PM (Merged)
2CARPRO JACK
  • 11,533 POSTS
front of engine below. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
ZARENA
The check engine light was on in my 2004 Ford mustang. The code that came up was P0340. Which is the camshaft position sensor.
I would like to know where I can locate the the camshaft sensor so that I can install it my self. This will be my first time, so if you can give me thorough instructions as well please?
CATAFINA
  • 167 POSTS
Refer to illustration:
HMAC300
  • 48,601 POSTS
unhook electrical, remove bolt and pull sensor out. reverse for reassembly
ZARENA
Catafina, that image doesn't look the same as my engine. On mine the belt is at the front of the car not to the side
Jan 18, 2019 at 5:48 PM (Merged)
HMAC300
  • 48,601 POSTS
robably have a 3.8L not a 3.9L it's below ignition coil
HMAC300
  • 48,601 POSTS
catafina is a member not one from 2carpros he sent you a pic of a 4cyl
MYSTARTERKIT15
I have a 2002 mustang v6 with 89,000 miles on it. Where is the camshaft sensor located and how do i replace it?
See below and select your engine in liter/s
https://images.2carpros.com/forum/automotive_pictures/12900_mustang_camshafrt_1.jpg
Inbox :: Message
To: rasmataz
Posted: Fri Sep 21, 2007 8:32 am
Subject: CAMSHAFT SENSOR
You replied to my question about the camshaft sensor but i cant really see what you put on there. its just kind of a blur. Could you just give me the internet site so i can see it?
thnks.
julie
Engine Liter
3.8L on from of engine below ignition coil
4.6 on left front of engine
MIKEWADE420
Engine Performance problem
2003 Ford Mustang V8 Two Wheel Drive Manual
where is the cam shaft sensor located?
DOCFIXIT
  • 18,828 POSTS
Left front side engine just below PS resivor
LGILLESPIE1967
The car does start hard after warmed up. The left side head sensor is obvious behind the steering pump reservoir. The right side sensor is not in the same position. Perhaps The Chilton manual Ihave does a poor job of showing the location. It also does not confirm that the right side of engine is bank A.
FIXITMR
  • 9,990 POSTS
Your Cam Position Sensor is located on the right side of the engine if you're looking at it from the front. It is a little black thing right under the valve cover.
ANTHONY19
engine light came on diagnosis said camshaft sensor replaced it but my engine light is still on even when I take my battery post off it comes on again what should I do?
BLUELIGHTNIN6
  • 16,542 POSTS
you need to have the trouble code erased using a scan tool, removing battery cable does not work on newer vehicles such as this. the code is still stored even with battery disconnected.
STANGINSEAN
I recently got a check engine light come on and scanned it and got the code P0340 which is Camshaft Position Sensor. So me and a buddy cleaned it and tested and ruled out the wires. So I came to the conclusion that itd have to be to the Sensor then, but I have read about the Alternator causing the problem with interference. How would I go about testing if this is the case instead of playing a guessing game and replacing the alternator & the Sensor?
DAVE H
  • 13,384 POSTS
the interference gets in by the wiring connectors insulation not being on correctly as long as it is insulated correctly there should be no interference .. try adding a little more insulation, clean sensor, clear codes and drive vehicle around to test ?
CORYPOST
My 2002 Ford Mustang 3.8L mustang with 64,800 miles is having an issue with the Cam Positioning Sensor (CPS). While I was driving, it started stuttering, like I put bad gas in it. Then a few miles later the check engine light came on. I drove it straight to Advance Auto Parts and had them hook it up to the computer. The computer said it was the CPS. I tried to drive it the next morning and it worked ok then it started really stuttering. Literally felt like something was grabbing the pulleys/belt and stopping it then letting it go again. Eventually, it stalled completely and wouldn't start again for a few hours. After I started it would stall any time I'd stop. I replaced the CPS and it is still doing the stuttering thing anytime I go over about 1500 RPM's. I have checked the coils and all the cylinders are firing. What could the problem be?
[quote:f46ab06cd7="CoRyPost"]My 2002 Ford Mustang 3.8L mustang with 64,800 miles is having an issue with the Cam Positioning Sensor (CPS). While I was driving, it started stuttering, like I put bad gas in it. Then a few miles later the check engine light came on. I drove it straight to Advance Auto Parts and had them hook it up to the computer. The computer said it was the CPS. I tried to drive it the next morning and it worked ok then it started really stuttering. Literally felt like something was grabbing the pulleys/belt and stopping it then letting it go again. Eventually, it stalled completely and wouldn't start again for a few hours. After I started it would stall any time I'd stop. I replaced the CPS and it is still doing the stuttering thing anytime I go over about 1500 RPM's. I have checked the coils and all the cylinders are firing. What could the problem be?[/quote:f46ab06cd7]
Your engine has both the CMP and CKP sensors -check the crankshaft position sensor-when it stalls check for spark.
BADAMS1977
I replaced cam synchronizer and position sensor. I bought a tool set to align synchro but I don't know which one to use. There are four colors, gray, black, blue, and yellow. Which tool color is correct?
WRENCHTECH
  • 20,761 POSTS
Only one of them will fit your synchronizer correctly. They may even be marked to what engine they are for.
BWATSON23
Electrical problem
2004 Ford Mustang 6 cyl Two Wheel Drive Automatic
whare is the camshaft position sensor and if its bad could it cause a squeeling noise?
BMRFIXIT
  • 19,053 POSTS
Camshaft Position Sensor (3.8L) located On front of engine, below ignition coil.
https://images.2carpros.com/forum/automotive_pictures/99387_1_26.jpg
cam sensor synchronizer will make noises
https://images.2carpros.com/forum/automotive_pictures/99387_1_27.jpg
BWATSON23
is that the same on the 3.9?
BMRFIXIT
  • 19,053 POSTS
center of front engine almost above W/P
https://images.2carpros.com/forum/automotive_pictures/99387_1_29.jpg
APRILFAIR
  • 30 POSTS
where is it located at/
