service engine soon light.
2002 FORD MUSTANG
96,000 MILES • 6 CYL • 2WD • MANUAL
SEBASTIAN RANGEL
on a 2002 ford mustang v6 5speed replaced a EGR valve and solve the service engine light for about a 2 months and recently drive for about 85 miles and light comes back again stays on since ,before light come back ussually drive short drives not more than 40 miles and was running fine.
Feb 14, 2011 at 6:42 PM
  • CAR REPAIR CONTRIBUTOR
Scan the computer for code/s might not be for the EGR valve this time.
Feb 14, 2011 at 6:52 PM
BOB ARGO
My Check Engine light came on and carried it to tech. and he said that the fuel sensor detected the
gas tank to full or it can do it if tank is close to empty.
I'm guilty of topping the tank as much as I can, even
overfilling sometime. I've never heard of this before and why didn't it go off over the past years that I
have overfilled? Is this a true reading?
Thanks, Bob
Apr 4, 2019 at 1:59 PM (Merged)
BLACKOP555
  • 10,386 POSTS
can you give me the exact code?
BOB ARGO
Sorry, I did not get code. So, I guess this ends my
question. After surfing around your web page, I
didn't know there were so many codes.
Thanks for your help. Bob Argo
BOB ARGO
I found my copy of the ticket and on it I located
the code. It's PO460
Thanks, Bob Argo
BLACKOP555
  • 10,386 POSTS
PO460 means fuel level sensor circuit malfunction.
means that the fuel tank sending unit is defective or that the wiring harness in the cluster to the unit is bad
PCANNEDY
Why does the Check Engine Light come on?
  • 31,937 POSTS
HI there,
The check engine light is an indication the one of the engine management sensors has failed or is out of range, the ECU take the information from all the sensors to operate the engine in optimum performance , if a sensor is out of range the ecu will log it as a fault code, this code is unique to each item it is monitoring so the code number is require to identify where your problem may lie.
Mark (mhpautos)
THEBOMB263
when idling my 02 mustang sounds great but when you get driving down the road it barely wants to run and the service engine soon light starts blinking their is a smell like raw gas fumes or something under the hood when checked at advance on computer it reads an agr code but if the llight is blinking when it is checked it reads cylinder misfire all new plugs and plug wires are in my car....please help.....
Misfiring can be caused by worn or fouled spark plugs, a weak spark (weak coil, bad spark plug wire), loss of compression, vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), an EGR valve that is stuck open, dirty fuel injectors, low fuel pressure, or even bad fuel.
JENNIE_28
This morning as I was driving to work my car started to pull really bad like i was stalling and wouldn't go past 3000 rpm and my engine light started blinking. Also heard a knocking sound too. what is the cause of that.
Apr 4, 2019 at 2:00 PM (Merged)
FISHERMAN
  • 937 POSTS
[quote:d5841643be="jennie_28"]This morning as I was driving to work my car started to pull really bad like i was stalling and wouldn't go past 3000 rpm and my engine light started blinking. Also heard a knocking sound too. what is the cause of that.[/quote:d5841643be]
Hello Jennie !
Did you continue driving the car ?
Check the Fluids as soon as possible !
Water, Coolant on reservoir, Engine Oil, Transmission oil and power steering fluid...
Let us know what is the condition and levels..
We Will be here waiting for your answer..
JENNIE_28
I had an engine misfire and did a diagnostic code p0401. I didn't continue driving I was only around the corner from my house so i turned around and got my other car. My husband will replace my spark plugs and my change my exhaust gas circulation.
FISHERMAN
  • 937 POSTS
[quote:2c19e6e3c6="jennie_28"]I had an engine misfire and did a diagnostic code p0401. I didn't continue driving I was only around the corner from my house so i turned around and got my other car. My husband will replace my spark plugs and my change my exhaust gas circulation.[/quote:2c19e6e3c6]
Hello !
got scared! I thought it was a low oil engine... (heard a knocking sound).
He Is Right..
P0401 Exhaust Gas Recirculation Flow Insufficient Detected
could be EGR Plugged or malfunction ..
Anyhow .. Let us know!
Good Luck and thanks a lot for your donation!
LILFIZZ1992
My 2002 mustang has the check engine light on. The DTCs it's giving me are: P1000, P0133, P1131. Now the O2 sensors are BRAND NEW, just replaced them. An so is the header gaskets, because I just put a full exhaust on it. But these code were on there before I did this, so I know it wasn't a mechanical mistake... But I can't find out what it is... Can you help?
RACEFAN966
  • 5,029 POSTS
Yes I can help. I will look up the codes when I get home and walk you through it if you still need help. So let me know if you haven't fixed it yet.
DOCFIXIT
  • 18,828 POSTS
P0133 Intake Air Temp sensor fault
P1000 Diagnostic not completed commonly set when BATT disconnected
P1131 HO2S-11 Rifht side bank O2 just before flange.
Try clearing see what resets
ANTHONYPERRYMAN85
My name is Tony. I have a 2002 Ford Mustang, 142K, V6 3.8L. I just changed the fuel filter the other day. But after a point in time of driving, it starts to bulk down and eventually cuts off. The check engine light is on. My uncle once told me that it might just be the spark plugs. He said it sounds like it's not getting all of the power. I haven't changed them yet. But do you think that is it?
BRUCE HUNT
  • 3,754 POSTS
I would be pulling them out not based on the uncle but because I would want to know how they looked. Take a look at them and see if one or more of them looks a bit black. I may be noticeable from viewing the plugs what is going on. Let us know what the condition of the plugs is.
2CARPRO JACK
  • 11,533 POSTS
Have the PCM scanned for the codes
LKOZZY
I have taken my 2002 Mustang into the shop several times for intermittent problems starting and running typically in , but not exclusive to, cold weather.
The engine turns over but will not "catch" and run on it's own without keeping the accelerator down slightly and keeping the RPMs up. Letting off the gas while braking will result in a stall.
The dealership can never find anything wrong. The problem seems to be one of those elusive ones that won't occur when it's in the shop and you feel like they are looking at you like you're crazy or something.
They said that the diagnostics test yielded no problems despite the SERVICE ENGINE SOON light being lit. The starter has been replaced but made no difference.
Any ideas other than the obvious "Take it somewhere else"? This Ford dealership is one of the only ones that honor my aftermarket extended warranty. (But that's a whole nother topic)
MERLIN2021
  • 17,250 POSTS
The first question to ask this "Dealer" is what are the codes, You are entitled to get a printout with the code numbers and meaning...have them supply it, and we can figure it out! You allready paid for it, so tell the service desk you want a copy!
CHUCKYB997
Ford 2002 Mustang GT Automatic V-8 sounded like a loud pop from rear of car then very loud sounding air noises and a clanking sound from front end started and continues each time its started back up no visible leaks from vhicle and check engine light not on at time and oil is registering on the dipstick when checked.
BMRFIXIT
  • 19,053 POSTS
Open hood and check for the source of the air leak
check vacuum lines and belts and so on
if not and or not sure
Should have it towed to a local shop and or have a tech take a look at it
REDNECKBARBIE
my mustang started misfire. the code said number one misfire. I put on new wires and plugs and air fllter. Service engine light went off but now when giving gas it sputters what could be wrong
DOCFIXIT
  • 18,828 POSTS
Correct plug and gap? wires seated well to plugs? Could debris have gotten on MAF when filter changed?
