gear oil is being forced up the speedometer cable?
1990 TOYOTA COROLLA
120,000 MILES • 4 CYL • FWD • AUTOMATIC
2CP-ARCHIVES
  • 4,540 POSTS
I had my radiator, alternator and starter replaced to keep me from being stuck in the snow. Last week, I smelled a strong smell in my car, and I found some kind of oil leaking from somewhere behind the dashboard down to my brake pedal. I took the car to garage, and they said the oil is from gearbox via speedometer cable. They replaced the O-ring and seal and charged me $85.00. Now here comes the worst: It starts leaking again! Before I go back to the garage, I am wondering if you could help me out by answering the following questions at your earliest convenience? This car is the only one my wife and I are using for everyday living, so please. 1. Is the oil really from gearbox, have the garage guys really made the correct judgment and done the right thing? 2. According to your experiences, what will be the next thing that will go down most likely or what things I should specially keep an eye on as for preventive maintenance?
Oct 15, 2010 at 4:24 AM
2CP-ARCHIVES
  • 4,540 POSTS
If gear oil is being forced up the speedometer cable, there is a good chance that the small air vent in the top of the transmission has somehow gotten plugged. As for your second question, a good thing to check, as preventive maintenance, would be the battery; have it load tested.
Oct 15, 2010 at 4:30 AM
