Mechanics
STARTING PROBLEMS
1985 Ford LTD
1985 Ford LTD 6 cyl Two Wheel Drive Automatic 185000 miles
Car wont start- it cranks over fine but just wont start. If you put some starting fluid in it, it starts fine and runs fine after that. After sitting for awhile, it wont start again unless you use starting fluid again.
MR FRG
December 29, 2008.
Next time it'll not start-check for power at the fuel pump connector-do you have it?
BTW do you hear the fuel pump when you turn key to run?
Rasmataz
Dec 29, 2008.
AD
