ABS light
2005 FORD FREESTAR
49,000 MILES • 6 CYL • FWD • AUTOMATIC
CK
my freestar the ABS light and brake light come on the speedo stops working the odometer shows dash dash etc. the trans ax light blinks the interoit light won,t work when you open the door. the automatic door locks don,t lock when all this goes on. this comes and goes at will also i can,t locate a shop manual for this van like haynes or chiltons.
Mar 8, 2008 at 1:24 PM
FLEXY5
  • CAR REPAIR CONTRIBUTOR
  • 512 POSTS
The vehicle needs a speed sensor. It should be on the output side of the transmission on the freestar. I believe it is located on the passenger side. Have a dealer look up the part and they can give you a printout of where it is located.
Mar 8, 2008 at 5:25 PM
ELLENA BOYKINS
My ABS light in my brake lights are staying on what could be my problem for my 2005 Ford Freestar
Jan 5, 2020 at 11:02 AM
  • 54,350 POSTS
9 times out of 10 it will be one of the wheel speed sensors is a guide here is a video to help get the codes and a guide to help you test them manually.
https://youtu.be/rTtAnsOlZU4
and
https://www.2carpros.com/articles/abs-wheel-speed-sensor-test
Jan 5, 2020 at 12:45 PM
BOBCRZ215
I have a 2004 Ford Free Star and something weird has been happening. Once in while when I am on the road I hear click sound sound (not clicking) one click sound and my radio goes dead, no time, no display no music nothing, and then the brake and ABS light turn on and sometimes the light (mileage display) goes away - after maybe 10 to 15 seconds there is a nother click and everything goes back to normal. When it happens I lose no power from the car, it keeps driving like normal if nothing happened.
That might occur about 4 - 5 times a day. What the heck do think it is? I appreciate your help.
Jan 6, 2020 at 9:44 AM (Merged)
HMAC300
  • 48,601 POSTS
it sounds like a relay from your description, check grounds body to battery, eng to battery see if that cures it.
