2005 Ford Focus Repair Question
2005 Ford Focus Alternator
How do you remave the alternator?
Answer
GENERATOR AND REGULATOR -2005 Ford Focus ZX4 S
Page 1 of 3
GENERATOR
All engines
1.Disconnect the battery. For additional information, refer to BATTERY, MOUNTING AND CABLES .
2.0L and 2.3L
2.Remove the upper generator nut.
Fig. 1: Removing Upper Generator Nut
Courtesy of FORD MOTOR CO.
2.0L PZEV
3.Remove the generator heat shield top nut.
Fig. 2: Removing Generator Heat Shield Top Nut Courtesy of FORD MOTOR CO.
All engines
4.Raise and support the vehicle. For additional information, refer to JACKING AND LIFTING . 5.Remove the screws and the accessory drive splash shield.
Fig. 3: Removing Screws And Accessory Drive Splash Shield
6.Release the accessory drive belt tension and remove the belt from the generator pulley.
Fig. 4: Removing Belt From Generator Pulley
2.0L PZEV
7.Remove the generator heat shield lower nut and the heat shield.
Fig. 5: Removing Generator Heat Shield Lower Nut And Heat Shield
All engines
8.Release the two air intake tube retainers and remove the air intake tube assembly.
Fig. 6: Releasing Two Air Intake Tube Retainers And Removing Air Intake Tube Assembly
7/25/2008
Page 2 of 3
NOTE: The B+ protective cover has been removed for illustrative purposes.
NOTE: 2.0L PZEV shown, 2.0L and 2.3L similar.
NOTE: The generator B+ cable nut must be replaced whenever it has been removed from the generator.
Fig. 7: Removing Generator B+ Cable Nut And Disconnecting B+ Cable
9.Remove and discard the generator B+ cable nut and disconnect the B+ cable. 10.Disconnect the generator electrical connector.
Fig. 8: Disconnecting Generator Electrical Connector
Fig. 9: Removing Generator Nuts And Bolt
11.Remove the two generator nuts and bolt.
2.0L PZEV
12.Lower the vehicle. For additional information, refer to JACKING AND LIFTING . 13.Remove the upper generator nut.
Fig. 10: Removing Upper Generator Nut
14.Raise and support the vehicle. For additional information, refer to JACKING AND LIFTING .
All engines
15.Remove the engine roll restrictor mount bolt.
Fig. 11: Removing Engine Roll Restrictor Mount Bolt
NOTE: This step will require an assistant.
16.Position the engine forward and remove the generator.
NOTE: Non-PZEV generator shown; PZEV generator similar.
NOTE: When installing the PZEV generator air duct, tighten the nuts to 4
7/25/2008
Page 3 of 3
Nm (35 lb-in).
Fig. 12: Removing Lower Air Duct
17.Remove the lower air duct.
ï¬ Remove the nuts (PZEV).
ï¬ Remove the bolt (non-PZEV).
Non-PZEV engines
18.Remove the radial adapter (B+ connection extension).
ï¬ Remove the cap from the rear of the radial adapter.
ï¬ Remove the radial adapter nut.
Fig. 13: Removing Radial Adapter (B+ Connection Extension)
19.To install, reverse the removal procedure.
7/25/2008
