Intermittent issue of the speedometer not working?
1989 PLYMOUTH ACCLAIM
130,000 MILES • 4 CYL • 2WD • AUTOMATIC
2CP-ARCHIVES
MEMBER
FOLLOW
1989 Plymouth Acclaim, mileage: 130,000. My speedometer doesn't work at times. How can I fix it?
Nov 2, 2010 at 6:46 PM
2CP-ARCHIVES
MEMBER
If your speedometer is cable driven, you will need to replace the cable. If it is electronically driven, try replacing the vehicle speed sensor in the transmission.
Nov 2, 2010 at 7:03 PM
