Mechanics
RADIO PROBLEM
2003 Ford Focus
2003 Ford Focus
Does anyone know how to remove the 6 disc cd player from a 2003 Ford Focus?
AD
Niteflower
June 7, 2008.
You can use a coat hanger, rip off to equal size pieces of metal and stick each end into the holes to the right and left of your unit.
Jiggle them in there as you would a key.
Then pull out left and right a bit (as if you were opening your hands in a small opening after just having them together)
then pull out towards you and the radio should come out.
Disconnect the wire harness in the back and you should be good to go.
Ehlin
Jul 1, 2008.
AD
