Mechanics
FUEL???
2001 Ford Focus
Engine Performance problem
2001 Ford Focus 4 cyl Front Wheel Drive Automatic 103000 miles
my car died on me so I had it towed and replaced the fuel pump, started the car back up after fuel pump was fixed it started right up however tried to drive it and it started to putter and then died again. Cant check fuel pressure dont have the proper tool, do you think it could be the fuel pressure sensor that is out now? And if so how can you tell if that is the problem?
Stalks72@aol.com
December 9, 2009.
Hi stalks72@aol. Com and TY for the donation
The only way to finger the fuel system is to actually check the fuel pressure with a gauge this is a critical check that must be done-EFI don't like low fuel pressures-lets get the reading taken and comeback with it so that we can continue to assist in this matter.
AD
Rasmataz
Dec 9, 2009.
Actually I was looking on websites and I just found out that ford has done a recall to my fuel delivery system therefore I am wondering now if that is the problem
Stalks72@aol.com
Dec 9, 2009.
AD
