Mechanics
HEATER DONT WORK
2000 Ford Focus
Heater problem
2000 Ford Focus Automatic
THE FAN WILL NOT WORK. NOTHING COMES ON
AD
EVILEE
December 13, 2008.
SYSTEM TESTS
BLOWER MOTOR DOES NOT OPERATE
Check fuse No. 64 (30-amp) in Battery Junction Box (BJB), located in left rear corner of engine compartment. If fuse is blown, replace fuse. If fuse blows again, repair short to ground in Green/Orange wire between fuse No. 64 (30-amp) in BJB and terminal No. 1 of heater blower motor. If fuse is okay, go to next step.
Turn ignition off. Disconnect blower motor harness connector. Turn ignition on. Measure voltage between ground and terminal No. 1 (Green/Orange wire) of blower motor harness connector. If battery voltage exists, go to next step. If battery voltage does not exist, repair short to ground in Green/Orange wire between fuse No. 64 (30-amp) in BJB and heater blower motor.
Turn ignition off. Measure resistance between ground and terminal No. 2 (Black/Red wire) of blower motor. If resistance is 5 ohms or less, replace heater blower motor. See BLOWER MOTOR under REMOVAL & INSTALLATION. If resistance is more than 5 ohms, go to next step.
Disconnect blower switch. Measure resistance between terminal No. 2 (Black/Red wire) of heater blower motor harness connector and terminal No. 4 (Black/Orange wire) of heater blower switch harness connector. If resistance is 5 ohms or less, go to next step. If resistance is more than 5 ohms, repair open in wire between blower motor and blower motor switch.
Measure resistance between ground and terminal No. 6 (Black wire) of blower switch. If resistance is 5 ohms or less, replace blower motor switch. If resistance is more than 5 ohms, repair open between blower motor switch and ground (located at left " A" pillar).
Dave H
Dec 13, 2008.
AD
