Mechanics
FUEL FILTER
2000 Ford Focus
2000 Ford Focus
instructions on how to change fuel filter on 2000 ford focus 16valve dual overhead cam
thanks
Touriesmom
January 3, 2009.
Turn ignition off
Disconnect the battery ground cable
Relieve the fuel system pressure.
Raise and support vehicle.
Remove left front wheel.
Remove left wheel well splash shield including screws and pin type fasteners.
Disconnect the fuel line R shaped clip fittings.
Remove the bolt at the fuel filter bracket and remove fuel filter.
Buddycraigg
Jan 3, 2009.
AD
