Mechanics
F350 ENGINE STALLS/IDLES ROUGH
1989 Ford F-350
Engine Performance problem
1989 Ford F350 V8 Four Wheel Drive Automatic 170000 miles
Engine idles a bit rough but not bad. Engine stalls after reving the engine. Almost like its choking. Seems like the rpm's are way too low. Starts cold at 500-600rpm's. Is this normal? Also am doing all the basic maintenance since we just got it a week ago and I don't seem to see the drain plug for the transmission. Do I have to drop the whole pan on this one?
Lithoton
April 16, 2010.
Clean out the idle air control valve/mtr/ISC and test the throttle position and mass airflow sensors
Rasmataz
Apr 17, 2010.
AD
