Ford F-250 Repair Question
Topics covered: Bump, Distributor, Engine.
Asked on February 12, 2007
Timing off
The timing on my 86 f-250 4x4 with 5.8 litre engine is not kosher something is wrong with it when #1 is at top dead center on intake stroke the timing mark is 180 degrees out i have pulled the distributor out and reset but truck would not run also have moved wires 180 deg but still wont work could it have wrong harmonic balancer installed truck runs very sluggish and very slow revving up it also has automatic tranny and holley 4 barrel
Answer
Replied on February 12, 2007
check real close and make for positive you have the timing mark if i remember right some of those have 2-3 marks on it and it will throw you off.
Replied on February 13, 2007
you are correct it has 3 marks on it but none are anywhere close at TDC or 180 out i have timed a lot of vehicles but this one threw me off and i was wondering if there was a way to fix it without teardown
i think the only thing you could do at this point is to remove the #1 spark plug whitch is the first one on the pasenger side,have someone turn the motor over little bumps at a time,with your finger over the hole in#1 cyl,as you feal comp,stop then recheck for timing mark,and readjust dist, to #1,with this done you should get something out of the truck.
