Ford F-250 Repair Question
Topics covered: Brakes.
Asked on January 11, 2007
Brake trouble
Hi, I was wondering if you had any information on why my 1993 Ford f250 3/4 ton's front brakes are not fully releasing? It will come to a complete stop without use of the break pedal. I have replaced the left caliper, both lines, master cylinder, and booster. But yet the pads are always rubbing, and then will result in smoking from both the calipers. I would greatly appreciate any info regarding this matter. Thank you.
-Dallas
-Dallas
Answer
Replied on January 11, 2007
you need to check and or adjust your brake booster rod it sounds like its to far out try turning it in just a little
