Mechanics
F250 FUEL TANK ISSUES
1997 Ford F-250
Electrical problem
1997 Ford F250 V8 Four Wheel Drive Automatic 80600 miles
Hello, my question is in regards to my rear fuel tank on my 1997 f-250. I hit the rear tank switch and the truck turns of while I'm driving. I filled up the rear tank two days ago, and now I have no access to it, please help.
Hluna13
March 26, 2008.
With the ignition on and the switch on the rear tank, pull the wiring connector off the tank and see if your getting voltage, if you are but not fuel coming out or pump response the pump is bad, if no voltage then you need a new switch more then likely.
Blackop555
Mar 26, 2008.
AD
