Mechanics
F250 FOUR WHEEL DRIVE WILL NOT KICK IN.
1997 Ford F-250
1997 Ford F250 V8 Four Wheel Drive Automatic 197000 miles
MY TRUCK HAS A FOUR WHEEL DRIVE SWITCH. WHEN I TURN THE SWITCH TO FOUR WHEEL DRIVE - THEN THE " FRONT" DRIVESHAFT WILL TURN ON - BUT FOR SOME REASON THE HUBS WILL NOT GO IN TO THE FOUR WHEEL DRIVE MODE. MY TRUCK HAS NO MANUEL HUBS - IT IS AUTOMATIC - OR SHOULD BE. MY TRUCK HAS VACUUM SYSTEM THAT WORK IN CONJUNCTION WITH THE FOUR WHEEL DRIVE SWITCH IN THE CABIN. WHEN I TURN THE FOUR WHEEL SWITCH TO 4-WHEEL DRIVE - THEN THE VACUUM SYSTEM WILL WORK - BUT, I DO NOT GET FOUR WHEEL DRIVE. THE HUBS WILL NOT KICK IN TO THE FOUR DRIVE MODE. WHAT'S WRONG? THANK YOU. LARRY POND.
LARRY POND
September 21, 2009.
Check out the related content below while we wait for the question to be answered by a professional mechanic.
