1997 Ford F-250 Repair Question
Asked on January 20, 2006
1997 Ford F-250 fuel tank switch problem
344,785 miles. The front tank is full, but will not switch over. I can only use the rear tank.
Answer
Replied on January 20, 2006
I would take that tank out clean it replace all the fuel lines sound like a breather tube or something is plugged up and not letting it create a vacuum to get to the other tank
Replied on January 21, 2006
When you throw the fuel tank switch in the cab, what is it doing? Is there a valve or something outside the tank that might not be working? :?:
