Ford F-150 Repair Question
Asked on October 25, 2006
Wipers wont work
94 Ford F-150
The wipers will not work all the sudden. When I turn on the switch thingy, i just hear a clicking sound coming from inside the dash/glove box area.
Fuse?
Relay?
Motor?
Thanks
Fuse?
Relay?
Motor?
Thanks
Answer
Replied on October 26, 2006
Try to use the wipers by the windsheild cleaning function. If that works then, the motor is still good. If not, the motor could be bad, but I would check all fuses first.
I would strongly suggest that the wiper switch is bad. I have one and the switch has failed like that.
my friend said the direct wire the wiper motor to the battery to see if the motor works. If that works, then either the relay-box, or the switch. I already replaced the fuse...that didnt solve anything
Replied on October 28, 2006
We direct wired the motor to the battery, and nothing happened...no jiuce. So the motor is crap
