Ignition timing?
LOU761
  • 1992 FORD F-150
  • V8
  • 4WD
  • MANUAL
  • 158,000 MILES
How to set the ignition timing?
Do you
have the same problem?
Thursday, December 4th, 2008 AT 12:06 PM
BLACKOP555
  • 10,371 POSTS
Run the vehicle a few miles until it is at proper operating temperature.
Then pop the hood and attach timing light. Next climb under the vehicle and mark 10 degrees before top dead center with a piece of chalk for visibility.
Next pull the spout connector out right by the distributor, after that is done, loosen the distributor enough to turn it by hand but not the idling engine vibrations to change.
Then start vehicle and alight the 10degree line to the marker on the vehicle, torque down the distributor and shut off vehicle.
Remove the timing light, and put back in the spout connector and your good to go.
Saturday, December 6th, 2008 AT 8:20 AM
GYESIONEK
  • 1991 FORD F-150
  • V8
  • 163,000 MILES
My 1991 Ford Lariat; V8, EFI, 5.0L seems to have an acceleration problem. Even in neutral, if I rev the motor, at about 1200-1800 RPM the motor seems to "bog down". When the RPM reaches 1800+ the truck seems to run fine. I suspect the TFI-IV module in that I failed the California Smog Test in the ignition timing section. My Chilton book says there is no adjustment for BT and AT yet he says I need to have an timing adjustment so that my PPM of Hydro Carbons are within limits. Thank you in advance.
Thursday, October 22nd, 2020 AT 10:50 AM (Merged)
INDYUKE
  • 416 POSTS
The only thing you can set is base ignition timing. The ECM takes care of timing on a moment by moment basis after the engine is running.
In order to set base timing you need to disconnect the spout connector, start the truck and set timing to about 10 deg BTC. Some people set it as high as 13 deg, but then you run the risk of detonation at that setting, plus emissions tends to go up the more you advance the timing.
Shut the truck off, reconnect the spout connector and that should do it for ignition timing.
The spount connector is a little plastic doohicky on the wire bundle coming off the TFI module. I just pull it out and set it somewhere safe while setting the timing.
RALPH MCCORMICK
  • 1988 FORD F-150
  • 5.0L
  • V8
  • 100,000 MILES
First thank all who have given me advice it has helped narrowing down my problems. So okay, my truck is running and now my gas gauge works but I drove it today and it seems to have no power from a stand still until I floor board the accelerator. I think I have a small exhaust leak, but nothing to bad, it does not have a catalytic converter on it, but I think the guy helping did adjust the timing a little. Any ideas? Thanks again in advanced.
Thursday, October 22nd, 2020 AT 10:51 AM (Merged)
CARADIODOC
  • 33,699 POSTS
I do not know what the rest of the story is, but for the symptom you described, look at the fresh air tube between the air cleaner and the throttle body. If any air sneaks in through a leak, it wont get measured by the sensor and no fuel will be added to the fuel metering calculations.
This is a vacuum leak guide that will help with this.
Please let us know if you have other questions. Thanks
JONBOATKING
  • FORD F-150
1993 f150 5.0 liter. I understand that in order to set the initial timing that I have to disconnect the inline SPOUT. I do not know where this is. An exploded view of the TFI distributor shows the spout but not the location.
TAURUSWHEEL
  • 718 POSTS
It's usually right near the base of the distributor, or I'm thinking also could be near base of tfi depending on model, hangs off the wire harness, small plastic part(2 pieces) at the end of a couple of wires. From the factory usually the end plug(which you will pull out) is wrapped with friction or some sort of black tape. When you disconnect it, engine will revert to base timing
