Mechanics
F150 INSTRUMENT PANEL
1915 Ford F-150
When I start up my 1998 Ford F150 the car starts just fine, but the instrument panel does not work. This includes the spedometer, odometer, and all the pressure gauges. Is this a fuse issue and if so, what can be done to fix it?
Bwomack
July 31, 2006.
There may be an issue with the main electrical connector to the printed circuit panel, which would require you getting access to behind the panel to check it out, could also be the gem module, is this an electronic dash, with digital speedo, or analog speedo?
TaurusWheel
Jul 31, 2006.
