Mechanics
BRAKE BLEEDING , 2WD, AUTOMATIC, 130,000 MILE
1990 Ford F-150
I 'm trying to bleed my brakes on my 1990 ford f-150,302 v8, 2wd, auto, 130,000 miles. I have rear antilock brakes and was told there is a valve I would have to reset first, before I can bleed them. My question is where is this reset valve located?
Mrocray
August 5, 2007.
You need to make a tool to hold out a pin on the proportioning valve in order to bleed the front calipers. Don't forget to remove the tool after bleeding
Wejones
Aug 17, 2007.
AD
