Mechanics
F150 REAR DIFFERENTIAL
2005 Ford F-150
Drive Train Axles Bearings problem
2005 Ford F150 V8 Two Wheel Drive Automatic 54000 miles
There is a " bump" in the rear end when taking off from a stop.
Vas Is Los?
Joehowards
December 3, 2009.
Is the gear lube clean and full? Also, check to make sure there are no worn bushings onthe leaf springs or a loose shock.
Let me know what you find.
