2CarPros - Car Questions & Answers
2004 Ford F-150 Repair Question
Topics covered: Door, Interior, Door lock.
Asked on March 10, 2009
2004 Ford F150 Courtesy features problem
Electrical problem
2004 Ford F150 V8 Four Wheel Drive Automatic 114000 miles
I own a 2004 Ford F-150 (NOT Heritage) Super Crew Cab (4 Door) Lariat, 5.4L, 4 X 4, with 114K miles. It has a Code Alarm APS-997 Alarm/Remote Start system, which has been installed and functioning since the truck was new.
Recently, after opening and closing both drivers’ side doors, the DIC indicated that there was a DOOR AJAR when the truck was put in gear/drive. I returned to Park and found that all doors were shut. I then opened and closed the drivers’ side doors and drove away. The DOOR AJAR indication light was no longer activated.
Since doing that, I have noticed that:
• The door locks do not automatically lock when in drive and operating.
• The chime for the ignition key left in the ignition does not function.
• The chime for the headlights inadvertently left ‘on’ does not function.
• The odometer (DIC indication) does not illuminate when the door is opened.
• The interior/courtesy lights do not illuminate when the door is opened. They do work when manually operated from the headlight switch or the ‘push’ lens switch at the individual light.
• The DOOR AJAR indication does not work
All of the remaining functions work as they should and the alarm/remote start work as it always has.
I would like to correct/repair these malfunctions, especially the interior light failure.
Can you suggest a course of action to restore these functions.
Avatar Asked by gah069
No Answer Yet
