F150 CODES---P2106 WITH C1230
2004 Ford F-150
Engine Performance problem
2004 Ford F150 V8 Two Wheel Drive Automatic 78,000 miles
I have the wrench light and ABS light on dash with codes P2106 and C1230? Can I repair this?
February 12, 2010.
Ok P2106 has to do with the EGR system module to do more diagnostics on this you will need a scan tool and maybe a digital multi meter.
C1230 is the commonly the rear speed sensor on the top of the differential or one of the front speed sensors. With a digital multi meter this can be tested to see which it is. Let me know what you want to do. I will walk you through the tests.
Feb 13, 2010.
