Mechanics
F150 CHECK ENGINE LIGHT
2004 Ford F-150
Engine Performance problem
2004 Ford F150 V8 Four Wheel Drive Automatic 60000 miles
The check engine light came on in my truck and they told me that the codes on the computer were 2195 and 2197. Can you tell me waht these codes mean, the mecanic tells me that it is the throttle body?
JANETTE96
January 5, 2009.
P0171, P0174, P1130, P1131, P1150, P1151, P2195 or P2197
H18 CARRY OUT A VISUAL INSPECTION ON THE INTAKE AIR SYSTEM AND ALL VACUUM HOSES
Check the intake air system for leaks, obstructions, and damage.
Inspect the entire length of all the vacuum hoses for: proper connections.
Damage or cracks.
Damaged or cracked vacuum tees.
Verify the integrity of the positive crankcase ventilation (PCV) system.
Verify the proper PCV valve part number.
Dave H
Jan 5, 2009.
AD
