2CarPros - Car Questions & Answers
2003 Ford F-150 Repair Question
Topics covered: Engine, Fuse, Alternator.
Asked on October 11, 2010
2003 Ford F-150 theft/ecu/ecm
Electrical problem
2003 Ford F-150 6 cyl Two Wheel Drive Manual 90000 miles
truck was driving fine with no signs of trouble when the truck had stalled. attempted to restart with no luck. fuel rail has pressure and engine has spark. engine cranks but will not start.
the signs i am experiencing are as follows:
engine will crank but wont start. theft light blinking(fast). odometer does not show mileage only dashes (). all fuses are in good condition. code scanner can not connect to vehicle
things i have tried are as follows:
checked all fuses. made sure no loose connections on battery and other electrical connectors. in the process of having the alternator checked out (just in case).
Avatar Asked by tilifish
No Answer Yet
