2CarPros - Car Questions & Answers
2002 Ford F-150 Repair Question
Topics covered: Engine, Compression, Compression test.
Asked on February 27, 2009
2002 Ford F150 Need help
Engine Performance problem
2002 Ford F150 6 cyl Two Wheel Drive Automatic 160000 miles
/Truck sounds like it is "missing" while idiling. When it is running down the road, slight exceleration will cause the engine to run rough. The truck is also using way more gas then it should be. I have replaced the plugs and wires, and had the fuel system cleaned out. oil changes have been on time. What needs to happen?
Avatar Asked by detroitvagabond
Answer
Replied on February 27, 2009
hi compression test is next if ok then move on to injector testing
Tiny Answered by billymac (expert)
2,255 answers provided
