2CarPros - Car Questions & Answers
2002 Ford F-150 Repair Question
Topics covered: Fuel pressure, Engine, Fuel pressure regulator.
Asked on June 9, 2010
2002 Ford F150 Engine runs rough
Engine Performance problem
2002 Ford F150 V8 Four Wheel Drive Automatic 205000 miles
My engine is throwing a code (lean on bank2). It seems to be running a little rough between 1200 to 1600 RPM's (it is not as noticable at higher RPM's). I have recently changed the fuel filter, sparkplugs and 2 COP's. I have check my fuel pressure and it is only 32psi instead of 55 psi. I have hooked an OBD-III to read the codes and the freeze data shows that my LTFT% is around 24 to 27.Any ideas with this problem will be gratly appreciated
Avatar Asked by brwhiteman147
Answer
Replied on June 9, 2010
sounds like the fuel trim is about right for a vehicle running with a lean condition and low fuel pressure.
take vaccum line off of fuel pressure regulator. does pressure come up? notice fuel leaking out of fuel pressure regulator? if that all seems good next thing to do is change fuel pressure. after that its time to start looking at pump output
Tiny Answered by blackop555 (expert)
10,902 answers provided
