Mechanics
F150 PLUGGED HEATER CORE
2000 Ford F-150
Engine Cooling problem
2000 Ford F150 V8 Four Wheel Drive Automatic 130000 miles
not leaking yet is there anything on the market to flush the cooling system that works?
Bigjohn1
July 8, 2008.
If it heat that you are looking for
check if the two heater hoses hot then its not the heater core its the blend door motor under the dash.
If hoses not hot
u can remove the two heater hoses and flush heater core by using a garden hose and blast of air
BMRFIXIT
Jul 9, 2008.
AD
