P0354 cant find bad coil
JHNSNBRDLY
  • FORD F-150
F150 ford 1999 180000ml 5.4L the code i got from the diagnostic is P0354 but i dont know which ignition coil is D. my truck is misfiring mosty when i put it in drive and i would like to know if it is the coil or something else. the code said P0354 ignition coil D primary/sencondary circuit malfuntion thank you
http://www.2carpros.com/forum/automotive_pictures/82440_DSC00259_1.jpg
Thursday, June 28th, 2007 AT 2:04 PM
98RANGERXLT
  • 301 POSTS
Your engine has whats called coil on plugs for every spark plug there is a coil. Here is a guide to help you find the coil that is not working
Thursday, June 28th, 2007 AT 8:02 PM
BRADTLEW
  • 1999 FORD F-150
  • V8
  • 4WD
  • 80,000 MILES
I've had a similar problem as many people with the misfiring of a cylinder, when I pull the code, PO354, coil D malfunction, how does this correlate to the cylinder number? I have yet to find anything, on the internet anyways, showing me COP wiring diagram.
Wednesday, April 3rd, 2019 AT 12:29 PM (Merged)
BRADTLEW
Apparently the code reader I have does in fact just list cyclinders 1-8 as A-H, so D, cylinder 4, had a bad coild pack and fouled plug. Replaced and works fine now.
