1999 Ford F-150
Engine Mechanical problem
1999 Ford F150 V8 Two Wheel Drive Automatic 98150 miles
the truck stop running. I was driving and the truck just stop running. I did try starting it and it won, t start.
July 15, 2010.
If it's cranking over but will not start-do below: Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, cap and rotor, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Jul 16, 2010.
