Mechanics
F150 MASTER CYLINDER BRAKE LINES
1999 Ford F-150
Brakes problem
1999 Ford F150 V8 Two Wheel Drive Automatic
I just replaced brake lines going from Master Cylinder to distribution block and I now question if I got the lines connected correctly. I rebuilt both lines so not so simple to verify. I connected rear Master Cylinder line (with fluid control valve) to farthest distribution inlet (toward engine) and front Master Cylinder line to outer most (toward wheel) distribution inlet. Correct or is that reversed? I can't get brakes to firm up. Little to no air found in lines when bled. Did I possibly not bleed each line long enough to get air behind the fluid? No brake lines are leaking.
HMS200
January 2, 2009.
Check out the related content below while we wait for the question to be answered by a professional mechanic.
AD
