Outside parking lights not turning off
CLAUDIO ARCE
  • 2000 FORD F-150
  • 4.2L
  • V6
  • MANUAL
  • 195,500 MILES
For the first time yesterday my parking lights will not turn off without disconnecting the battery pulled the switch out and lights stay on. It does have trailer hook up factory installed. Please help
Monday, May 29th, 2017 AT 9:02 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,883 POSTS
Yep there is a parking light control relay that is stuck on and it needs to be replaced, here is a parking light wiring diagram (BELOW) and a guide to help you do some testing to be sure.
and
Here are all the fuse and relay diagrams as well.
Please run some tests and get back to us so we can continue helping you.
Cheers, Ken
Wednesday, May 31st, 2017 AT 3:44 PM
  • 0 POST
  • 2007 FORD F-150
Tail lights stay on when truck is turn off
Wednesday, May 31st, 2017 AT 3:46 PM (Merged)
WRENCHTECH
  • 20,757 POSTS
Are you sure it's the tail lights or could it be the brake lights?
  • 0 POST
  • 2002 FORD F-150
  • 150,000 MILES
Headlights stay on after shuting off and running lights not working
HMAC300
  • 48,601 POSTS
Your headlamps should stay on for about 30 seconds after shutting engine off, but check ground for auto headlamp module it's in the right kick panel. See if running lights are gettin g power an d bulbs are good.
CARDUDE13
  • 1999 FORD F-150
  • 6 CYL
  • MANUAL
  • 173,000 MILES
Electrical problem
1999 Ford F-150 6 cyl Two Wheel Drive Manual 173000 miles
My 1999 f-150 xl base model, no power windows, locks etc. Every time I turn my lights on and off, my parking lights will stay on till I disconnect the battery. Then they will be off. Till next time I turn them on again. I do not have Auto Headlights or alarm system.
What could be the problem? Where do I start looking?
JDL
  • 16,098 POSTS
My info shows two ways for those lamps to get voltage, lamp relay or headlamp switch. You could pull the lamp relay, see if the problem goes away, just for testing. It is the lamp module that grounds the relay.
https://www.2carpros.com/forum/automotive_pictures/170934_ford_f150_lamps_1.jpg
CARDUDE13
I TOOK OUT RELAY 201 AND IT FIXED THE PROBLEM. I SWAPPED THE RELAYS AROUND WITH NO IMPROVEMENT. BUT WHEN I DO NOT HAVE A RELAY IN SLOT 201 THE LIGHTS WORK PERFECTLY. I HOPE THIS HELPS OTHERS.
