2CarPros - Car Questions & Answers
1998 Ford F-150 Repair Question
Topics covered: Four wheel drive, Wheel, Repair manual.
Asked on March 10, 2009
1998 Ford F150 stuck 4x4
1998 Ford F150 Four Wheel Drive Automatic
I had to use my 4x4 low today. Now it will not come out of four wheel drive. It has the switch type on the dash. The indicator light stays on for 4 low and stays in 4 low.
Avatar Asked by elree
Answer
Replied on March 12, 2009
Ok I would first check all the vacuum lines to the front diff make sure none are leaking or cracked. If that is all fine then check the 4x4 module in the pass. side kick panal. Also may need to check the s4s shift motor. If you don't have a repair manual and need help walking through the module test then get back to me and I will look up that procedure. For now here is the vacuum diagram of the 4x4 system so you know what to check there.
http://www.2carpros.com/forum/automotive_pictures/249564_Graphic_12.jpg
Tiny Answered by racefan966 (expert)
4,866 answers provided
