2CarPros - Car Questions & Answers
1998 Ford F-150 Repair Question
Topics covered: Engine, Spark, Coil pack.
Asked on September 6, 2009
1998 Ford F150 no fuel
Engine Mechanical problem
1998 Ford F150 6 cyl Two Wheel Drive Automatic 94500 miles
My truck has acted like it was vapor locked several times in the past, and a few hours later it would start. I went to start it the other day, and it wouldn't start. I waited a while, and it still won't start. Any suggestions??
Avatar Asked by john38col
Answer
Replied on September 6, 2009
No start do below:
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor /distributor pick-up coil, ignition control module, ECM,Ignitor cam and crank sensors- Note: If it doesn't apply disregard it
Tiny Answered by rasmataz
68 questions asked
