Mechanics
F150 FUEL PUMP REPLACEMENT
1998 Ford F-150
Engine Performance problem
1998 Ford F150 V8 Two Wheel Drive Automatic 268, 00 miles
How do you replace the fuel pump?
Howard Johnson
January 10, 2009.
FUEL PUMP
Removal & Installation
Release fuel pressure. See FUEL SYSTEM PRESSURE RELEASE. Remove fuel tank. Remove screws or lock ring and fuel pump tank unit. Wipe seal area of tank clean. Position NEW seal onto pump mounting flange (if necessary), using grease to hold it in position. Position fuel pump in tank to original position. Install screws or lock ring. DO NOT overtighten lock ring, as it may leak. Install fuel tank.
Dave H
Jan 10, 2009.
AD
