1997 Ford F-150 Repair Question
Topics covered: Wheel, Brakes, Brake pedal.
Asked on February 28, 2009
1997 Ford F150 master cylinder
Brakes problem
1997 Ford F150 Four Wheel Drive Automatic
When we turn the wheel to the left the brake pedal sinks all the way to the floor as if it has no brakes, when we turn to the right it does not do that.
Answer
Replied on February 28, 2009
check the front wheel bearings. if a bearing is loose it will rock in and cause the caliper to compress and then you will need to pump pedal to get it to come back out
