Mechanics
F150 FUEL FILTER
1997 Ford F-150
Engine Mechanical problem
1997 Ford F150 V8 Four Wheel Drive Automatic
how to change
Rkawildman1966
July 1, 2010.
You release the fuel pressure first. I think you can do it by tripping the safty cut-off behind the passenger kick panal or you can take a fuel pressure tester and bleed it off at the valve under the hood. Then you will need the fitting tool to release the clips.
There is a tool you have to buy to release the filter.
It inserts into each end and then you pull the lines off. Your parts store should be able to help you.
Richzombie
Jul 1, 2010.
AD
